smdb
CM Devastator LED light autostart on Windows - GUIDE
azragarn    0
Sorry for digging up this old thread, but I wrote a small program that you can place in your startup directory that enables scroll lock.
Source: https://github.com/mrexodia/ScrollLock
Also attached the source+signed binary.
This works well, it turns on lights and scroll lock. Issues is i need Scroll lock disabled for the work i do but want the lights on
mrexodia    0
Modify your keyboard and solder a wire to permanently enable the lights, see http://atinyhedgehog.za.net/2014/12/cm-storm-devastator-keyboard-mod for more details.
Why you don't apply the 1th method? This is the simplest way...
I didn't search the web before coding this up, once finished I found this thread and decided to post my method anyway.
Method 3 worked for me! ^_^  *Note: If you attempted Method 1 before Method 3... Make sure to uninstall the Setup_Devastator MB24.msi. THE TWO METHODS CONFLICT WITH ONE ANOTHER.
Edited by ThereYaGoRookie
