Yaseen Davids
Antec P280 compatible with V8 GTS CPU Cooler?
Hi Guys
Just wanna know ( as the title says ) - Will the V8 GTS CPU Cooler fit in the Antec P280 White Window Case?
I intend to buy it but im not sure if it'll fit in the case - please assist
Hi Guys Just wanna know ( as the title says ) - Will the V8 GTS CPU Cooler fit in the Antec P280 White Window Case? I intend to buy it but im not sure if it'll fit in the case - please assist
here we go dude: this is your case u will see cpu suport in mm he say this case suport 170mm cpu cooler http://www.antec.com/product.php?id=704504&fid=6&lan=us
http://www.coolermaster.com/cooling/cpu-air-cooler/v8/?lv01_type=cooling&lv02_type=cpu-air-cooler&prd_path=v8-gts and this is cpu cooler and dimmensions are 166.5mm
so u have evrything what you need good lock i haope u will get it!!!!!!!!
