Bill
Need a CPU cooler for M-ITX that works in space and 84W TDF
Bill    0
Model RR-GMM4-16PK-R1 CPU Socket Intel Socket:
LGA 1366 / 1156 / 1155 / 1150 / 775
What is the TDF rating for the GeminII M4 cpu cooler? If this won't work can you recommend a CPU cooler that will given the height and TDF needs? Thanks.
I am building a M-ITX system using:
·         Cooler Master Elite 130 case
·         ASUS Z91I-Plus motherboard
·         Intel 4790 Devils Canyon CPU
I need to add a CPU cooler better than the Intel stock one. Concerns are:
·         Height – about 64mm clearance between CPU and bottom of power supply
·         TDF rating – 84w needed (plan to overclock the CPU)
knud    128
I would recommend to use an All-in-one water cooling solution. The Nepton 120XL would be a good choice :)
