Crebassa
How to adjust RPM for the Nepton 240M's pump
Crebassa    0
Hi
I would like to know how to adjust the pump speed (RPM) of my NEPTON 240M ?
Actually the pump is connected on the CPU Opt port (Motherboard Gigabyte Z97X-gaming5), and the CPU OPT fan speed control is "full speed" on the bios .
The CPU OPT fan speed control offered me several choices : Nomal / Silent / Manual / Full Speed
My question is : should i keep the "full speed" setting ? Is it good for the life span of my pump ?
My CPU's temperature is about 25° C so it works fine .
 Is it a good choice to let the pump turning in max power all time ?
Thanks for your answers .
Best regards .
