Jason J. Fedelem 0 Posted May 7, 2015 I recently purchased a CM Storm Devastator. I like it except for one thing: the only way to turn on the backlight is using the scroll lock key. This is fine except when I want to use Excel. With Scroll lock enabled, it "pans" back and forth when I use the arrow keys instead of moving cell to cell. Maybe I'm wanting to have my cake and eat it too, but it would be nice to be able to move cell to cell while also having the backlight on. Ideas? Quote Share this post Link to post Share on other sites
Pclinde 197 Posted May 16, 2015 Hi Jason, There is not other way to turn the backlight ON and OFF. Sorry, I can't help you with this issue. Cheers, Pim Quote Share this post Link to post Share on other sites
Jason J. Fedelem 0 Posted May 18, 2015 Thanks. Quote Share this post Link to post Share on other sites
Pclinde 197 Posted May 18, 2015 You're welcome. Quote Share this post Link to post Share on other sites
ctsonhcm 0 Posted May 22, 2015 Hi Jason, I use small script that sovle this problem. You can see in here Quote Share this post Link to post Share on other sites
Ken Harris 0 Posted August 5, 2015 Hi Jason, There is not other way to turn the backlight ON and OFF. Sorry, I can't help you with this issue. Cheers, Pim Hello, same problem, just wondering if there is a way to assign the LED ON/OFF function to another less used key tha the SCROLL LOCK? Thanks Ken Quote Share this post Link to post Share on other sites
