Pclinde
Cooler Master Water Cooling Support Guide
jawal    0
Had a Nepton 120XL for about 11 months and then the pump stopped working. Got a new one from the warranty but when i install it the pc keep restarting every 3-5 second. When i remove it i can see it has contact to the cpu but maybe not fully contact or hard enough. When i apply the stock cooler it works like normal. I have tried different pin connectors for the pump. The fan works as i can see it spin. Is there a sensor on the cpu(Intel 4770) maybe that keeps making it to restart?
johnnyabas    0
HI,
     I m newbie i would like to know where can i get back plate for support AM4 socket ,currently i used at my Intel motherboard and now i upgrade to AMD AM4 RYZEN i cannot used this Cooler Master Seidon 240M  anymore, my item has no more warranty,where can i get or buy this plate.
Mohd Noh    29
6 hours ago, johnnyabas said:
HI,
 Regarding this , please contact customer services via ticket as in my signature .
HI there ,
You can check this link : Upgrade Kit Compatibility
Henry ford    0
Hey im a New Pc Builder i never built a pc befor (Yes im a Noob) here is my build im going to buy https://pcpartpicker.com/user/djhenry88/saved/7XzxYJ except change the 1050 ti to a gtx 1060 and change the ryzen 5 1600x to the new ryzen that is coming out in February the ryzen 2400g now my question is since i have the MasterBox Lite 5 RGB is it compatible with the ML240L RGB?
I bought a cosmos 2 and a liquid cooling cooler master ml240l and it does not fit properly, this chassis has less space than my previous cosmos S, how to install the liquid in this chassis?
the only way that works is to put the radiator and the fans above by expelling air, and the pump remains with the letters of cooler master in vertical.
a box of € 400 just say that this is a failure for not having half a cm more
Mohd Noh    29
Hello
Can you share some picture ?
And i`d love suggest you by contacting customer services via ticket and they will assist you .
20 hours ago, Mohd Noh said:
Hello
I have not managed to put it another way, some idea or solution to have it properly placed?
support I attended once, I can not get care
