larry hoffman
does it matter from which direction tubing comes out of cooling block
Does it make any difference in which direction the cooling block is positioned on a socket 2011-3?  Can the block be positioned so the tubes face the bottom of the case rather than the front or back?  With the nepton 240m in my silencio 652s on a supermicro xeon single processor board, model X10SRA-F, I find there is considerably less tension on the tubes (and therefore on the cpu - cooling block - socket assembly/stack) than if the tubes exit towards the back or the front.  I have mounted the nepton 240m under the top of the case.  I have tried mounting it on the front of the case but it will only mount in one direction, with the tubes exiting the radiator at the bottom rather than at the top, and it is a long reach (~13") for the tubes to make it to the cpu location (perhaps even too long for the cooler block to be mounted on the cpu at all).
Pclinde    197
Hi Larry,
It shouldn't matter. The Nepton 240M and all other AIO sets are closed loops. The pump is on top of your CPU (the housing). The coolant will flow, and it doesn't matter which direction the tubes are.
Make sure the tubes don't kink! (don't worry the Nepton 240M is protected with anti kink around the tubes).
Cheers, Pim
Create an account
Register a new account
Sign in
Sign In Now
