P Hill
CM Stacker - Suggestion for simple improvement
P Hill    0
I for one have run out of usable PCI slots due to all of the PCI risers that are installed though there are still MB PCI slots free.
I have USB, Serial, Audio running from motherboard controllers as well as a fan controller for the CPU and don't have enough space to install the riser control for the crossflow fan.
A simple accessory would be a face plate for the second power supply space (assuming you don't use it nor add fans) that could add 3 or 4 riser spaces. It also has the advantage that the risers then don't prevent some PCI slots from being used.
