David Miracle
280 mm radiator, and HAF XB EVO???
I am confused about the documentation and product specs for HAF XB EVO case. The spec page on website says it supports 240 mm radiators. The spec page for nepton 280 mm closed loop cooling system says it is compatible with the HAF XB EVO case. The documentation also contradicts itself as the spec page says 240 mm radiator, but the installation page says 240/280 mm radiator. Does anybody know if it is possible to put a 280 mm radiator in this case? Has anybody done it successfully?
David Miracle
