Yu Qing Tan
System Stuck in a power on and off loop
Yu Qing Tan    0
My newly built com doesnt work, the system is stuck in a constant on and off loop, occasionally there will be a beep but usually it will shut down before that. I'm not sure if the power supply's the problem, but the mobo, rams, graphics card all seem to be fine as their fans and lights are all powered up for that few seconds, i suspect it might be the power supply but this is a new system so i'm not very sure. I tried to start the cpu without the rams but it still goes into a on and off loop, any suggestions to help this? I don't really want to go back down to the shop to fix it as i dont have the time...
