thelittlez97
help
PAK    4
hi, eithier alter youre bios seting to reduce the fan speed manual.
Or install a fan controller such as "speed fan" which allow manual control or automatic based on tempretures,
Pclinde    197
You can't control them now. Connect them onto the motherboard, or use a fan controller. :)
Sunday Morning    174
I'm not sure about that as the fans only connect to my psu.
Hi
my bro hv n300 and the rear fan we connect to motherboard
try connect direct into your motherboard and after try check you bios system
PAK    4
One fan on the motherboard I thought micro atx were stingy with two,
A front fan control is you best bet then plugs into mains and fans connect into that.
