Bili Piton
Nepton 240M Higher Temps than Hyper 412s
Bili Piton    1
I've recently replaced CPU air cooler (Hyper 412s) with Nepton 240M, and to my suprise temps are now worse. I'm running I7-3930K @3.8 GHz, and with 412s idle temps were ~23 °C which is ~3°C lower compared to Nepton 240M.  Are these temps normal for 240M? I've never had a water cooling before, so all advices are welcome.
Airflow HAF 922, 412s
Airflow HAF 922, 240M
HAF 922, Nepton 240M
HAF 922
Images of airflow before and now. Some people advise on using radiator fans as an intake, but that doesn't make much sense to me since the hotter air is always going up and it's blowing hot air form radiator back into the CPU
Sunday Morning    174
Hi Bili
Dang you nepton looking great
But U cn try this tips probably is useful for u.
Try reseat and repump your pump check your cable or wire make sure is correct and try loose alittle bit the screw.
good luck
