James Starkweather
Hyper D92 on ASRock Z97 Extreme6
CM Patrick    34
Hello James,
The CPU Fan 1 and CPU Fan 2 Headers should be linked in BIOS since they are specifically there for a Push/Pull setup. Connect one fan to CPU Fan 1 and the other to CPU Fan 2 and you should be able to control both simultaneously through BIOS.
Please let me know if you have any other questions.
Respectfully,
Patrick
CMUSA Support
I realize I should connect one fan to each CPU fan header, but I was looking for a little more specific config strategy.  On the ASRock mobo, the CPU Fan 1 header is 4 pin (PWM) and CPU Fan 2 header is 3 pin.  because both fans in Hyper D92 are 4 pin fans, I was wondering which fan would best be connected to the 4 pin header.  For example, is there any advantage say in connecting either the intake or the exhaust fan to the PWM enabled header?
Any insight would be appreciated.
Thanks,
Jim.
