Pawel
Nepton 280L - will it fit Silencio 452 case?
Pawel    0
Hi,
I ordered a silencio 452 case and a CPU cooler of a different brand, however the company i made the order with does not have the cooler I'm interested in and they offer me Nepton 280L.
Can someone please advise if it will fit?
I read the spec of silencio 452 and I can see that two 140 fans would fit but for liquid cooling it can only be 240 and not 280.
I just want to be absolutely sure that I would be right turning their offer down.
Thanks.
Sunday Morning    174
Hi Pawel
i try too answer your Q
According CM site : http://www.coolermaster.com/case/mid-tower-silent-series/silencio452/
Liquid Cooling System Front: 240mm radiator x 1 (optional)
Rear: 120mm radiator x 1 (optional)
so the answer is the Nepton 280L is not fit into your casing
maybe u can try nepton 240m and for more detail we need input from our admin :)
