TURKEY
CM Nepton 280L problems
TURKEY    0
Hi,
CM Nepton 280L I bought today..
I can not set the pump speed  :(((
Motherboard : MSIGaming 7
Working in continuous high speed.. ( 6500 rpm )
Bios, msi command center, speedfan ... no one is unable to control the fan speed !
CpuFan1 installed.. (is not)
CpuFan2 installed.. (is not)
TR - ENG
GOOGLE TRANSLATE
world    84
Does your motherboard change fanspeed based on PWM or voltage?
I know some motherboards only use PWM to change speed, and the Nepton pump does not use PWM, which could be why adjusting the speed isn't working right on your motherboard.
