Bruno Antonelli
Haf912 + LIQUID COOLING 240mm Inside
Hi guys,
i have a Haf912.
I want to buy a liquid cooling 240mm
Nepton 240 or Swiftech h220-x, both with radiator 240mm
Can i mount this system cooling all inside the case on the top place?
Thanks
Bye
knud    129
It won't fit by default, as there is no space on the inside; it can only fit on the outside of the case.
If you want to keep the HAF 912 you will need to take out the dremel and/or drilling tool and add some extra holes to the case :)
  • Upvote 1
Sure?
On the description in the official site "Top: 200 mm black fan x 1,700RPM,19dBA (can be swapped for two 120mm fans)"
I asked the question to know if anyone has already tried
Thanks
CM Patrick    34
Hello Bruno,
The case will support two 120mm fans at the top  but it will not support two 120mm fans and a radiator.
Unfortunately the HAF 912 does not have enough clearance for 240mm radiator so you will either need to purchase a 120mm liquid cooler or upgrade your case.
Please let me know if you have any other questions.
Respectfully,
Patrick
CMUSA Support
  • Upvote 1
Pclinde    197
Hi Bruno,
I would not recommend that. The case will be in between the radiator and the fans, this will decrease performance a lot.
Cheers, Pim
  • Upvote 1
CM Patrick    34
Hello Bruno,
There is also a strong possibility that the radiator will interfere with the motherboard making the installation very difficult.
Respectfully,
Patrick
CMUSA Support
Pclinde    197
I could mount Nepton 140xl with 1 fan 140 in push and 1 fan 120mm in pull for fix it on rear the case?
Or i risk that the radiator is very big than it slam with top or side?
Thanks
The HAF 912 supports a 120 mm fan on the rear. I would recommend the new Nepton 120xl: http://www.coolermaster.com/cooling/cpu-liquid-cooler/nepton-120xl/
Why? Great performance and low noise output, and it fits. :)
