Francesco Parodi
nepton 280L fan direction
i have a question..maybe stupid...if i mounting fans in the case cosmos SE like the images ...air must blow FROM THE CASE TO OUTSIDE or FROM OUTSIDE TO INTERNAL CASE? I hope I explained. thank you friends!
Sunday Morning    174
iam not expert cooling  :)
but i think for the best performance its depend on your situation but if i will take blow out the AIR   :)
or we ask our admin maybe they have solution for your question
world    84
I like having the air blow out of the case at the top, since hot air rises naturally.
That said, it's probably fine if you have the fans blowing into your case at the top. Just make sure you have enough exhaust for your case near the top (such as the rear case fan), or else the hot air might start pooling
CM Patrick    34
Hello Francesco,
The airflow direction of the radiator fans is really user preference. I personally have mine setup in the exhaust position so that the push the hot air out the top of the case.
Please let me know if you have any further questions
Respectfully,
Patrick
CMUSA Support
Pclinde    197
I would recommend push/pull. (Pull on the inside, push on the outside).
Cheers, Pim
ok but so i don't understand...escuse me...
nepton must be mounted (in cosmos SE) as in the picture below
how can the fans blow air out of the case if they are already out?
should take the air from outside, put it in the radiator that cools the liquid and bring out the exhaust air with other fans like the one on the back?
sorry if I insist, but I'm not understanding very well
CM Patrick    34
Hello Francisco,
The fans will pull air from inside the case, through the radiator and then out the top. All you need to do is flip the fans over :)
Respectfully,
Patrick
CMUSA Support
  • Upvote 1
