Bruno
Cooler for Xeon?
Bruno    0
I have a pc with tis spec:
Xeon E5620 2.4 Ghz
Motherboard: Gigabyte GA-7TCSV2
Power: Gigabyte 720
2 HDD WD 1T
Tower: Coolermaster Elite 334U Black
1 fan coolermaster
Best cooler from Coolermaster  for this processor?
Thks
Bruno    0
I have coolermaster Elite 33AU Black
The problema is the cooler that comes with the processor from intel is too noisy
world    84
Are you sure the model is the Elite 33AU? I don't see a case with that model (maybe I'm mistaken though)
Is your motherboard a dual 1366 socket board?
Bruno    0
Sorry the case is Elite 334U
Yes,  the board is dual, up  to two xeon processors 5500 or 5600 series
Sunday Morning    179
i suggest this : http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-tx3-evo/
Edit : and this : http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
but for hyper 212 evo iam not preety sure if is fitting into your casing
and the hyper 212 evo is good for your performance and silent...operation
  • Upvote 1
world    84
I guess that depends on your definition of silent :P
But, you can always throttle the speed using your motherboard if you plug it in through a motherboard header if it's too loud for you.
It looks like any cooler under 163 mm tall will fit. If you want a quieter cooling solution, you could always try these:
http://www.coolermaster.com/cooling/cpu-air-cooler/Hyper-612-ver2/
It is a lot larger than the 212 series, but that allows fans to spin at a much lower speed for the same amount of cooling.
Create an account
Register a new account
Sign in
Sign In Now
