bob86
Coolermaster K350 front fan dont work
bob86    0
Hi. I buy from Argos a Zoostorm i3-4160 2TB 8GB GTX760 Desktop PC with Coolermaster K350 case and notice that front fan does not working at all. Is this a issue or not, or is come on only on high temperature?
Here is a link with the pc: http://www.argos.co.uk/static/Product/partNumber/3560523.htm?cmpid=COJUN&cjsurferid=178702631550838124&mid=461876&sdc_id=1420257620z622877z39073b0a23261z&catalogId=10001&storeId=10151&_%24ja=tsid%3A11674%7Cprd%3A3086088&referredURL=http%3A%2F%2Fwww.argos.co.uk%2Fstatic%2FProduct%2FpartNumber%2F3560523.htm&referrer=COJUN#pdpFullProductInformation
Thanks
Pclinde    197
Hi Bob,
This fan should work. Contact Argos for warranty, or a replacement.
Cheers, Pim
  • Upvote 1
bob86    0
Thank you. I open the case and have a better look and looks like the forget a lose cable in there blocking the propeller fan, remove it and working fine. Thanks.
Pclinde    197
Glad to hear that!
Bondq    0
plz i need help i bought octane combo but i go problem with the mice says the device not recognized what should i do to fix this problem plz i need help
knud    128
Please create a ticket via the CM fanzone and our support staff will take it from there.
Create an account
Register a new account
Sign in
Sign In Now
