Brian Pinault
Cooler Master Nepton 240M
I have the Cooler Master Nepton 240M. Installing in Corsair 500r.
Should I put Rad on top with fans inside in push or pull, or Rad on outside with fans on top in push or pull configuration? The video instructions on Cooler Master site, shows Rad inside with fans on top in pull. Is this the best configuration?
Pclinde    197
I would go for the radiator on the inside, you have the space right? :D I would recommend push.
i agree with Pim ... if you have more space  .... the best choice is put the radiator inside :)
I don't have the room to put in push configuration with rad inside. I did put rad inside and fans on top in pull as in CM install video.
Sunday Morning    174
oic ... what you doing is good .. :)
no need to worry
