Kamil Koryszewski 0 Posted December 27, 2014 Hi, I just bought whole pc just waiting for the case. I've decided to buy HAF 912 Advanced with usb 3.0 There are two ver. of this case. KWN1: http://www.amazon.co.uk/Cooler-Master-Enhanced-Edition-Computer/dp/B004EWYSF8/ref=sr_1_1?ie=UTF8&qid=1419701898&sr=8-1&keywords=haf+912#productDetails KKN1: http://www.amazon.co.uk/Cooler-Master-Advanced-micro-ATX-5-25-Inch/dp/B009PV07TO/ref=sr_1_10?ie=UTF8&qid=1419701033&sr=8-10&keywords=haf+912#productDetails The only difference I see is the side window. Is this true? Amazon couldn't help me with that. Dimensions are same. The price is so much different though - 55 vs 80 !! Please help me with that - I need to buy case today/tomorrow. Thank you! Quote Share this post Link to post Share on other sites
Pclinde 197 Posted December 27, 2014 Hi, The only difference is the side panel. One without window, and one with window. KWN1, W = Window. Cheers, Pim Quote Share this post Link to post Share on other sites
Kamil Koryszewski 0 Posted December 29, 2014 Hmm that is very strange I have nearly bought non window one but my friend sent me videos from yt with reviews. Those are far different cases. KKN1 seams to be budget one: a) No black paint inside panel Just 2 fans (instead of 3 included in KW) c) No window d) Just one place for 3.5 hdd without using screws (4 in kw) e) Maybe few other stuff Can you confirm it? Here links KKN1 - KWN1 - http://www.impulsegamer.com/hardwarehaf912advanced.html / http://www.overclockers.co.uk/showproduct.php?prodid=CA-302-CM You can see there it looks different inside. Can you just look and check if you aren't mistaken? Thank you Quote Share this post Link to post Share on other sites
Kamil Koryszewski 0 Posted December 29, 2014 Hmm I think it is my fault this yt review is 912 not 912A ver. Ok I am buying the non window one:) Quote Share this post Link to post Share on other sites
Pclinde 197 Posted December 29, 2014 Hmm I think it is my fault this yt review is 912 not 912A ver. Ok I am buying the non window one:) Hi Kamil, Yes, it's the 912 standard version. The advanced version comes with a black coating on the inside. (Enjoy your new case)! Cheers, Pim Quote Share this post Link to post Share on other sites
