SiD996
seidon 120v blue led dead ?
SiD996    0
I glanced into my case today and to my horror the blue working led was not lit up on my seidon AIO ! . After a small panic attack and noticing my temps was still a steady 30oC  (very cold outside so central heating is on balls out) i decided to trouble shoot !.
So i disconnected the cpu power and boom temps started to rocket reconnect and down they come .
this does make me feel better but im still worried about my pump unit, has anyone eles had this issue ? according to my asus suite its running at 2360 rpm at full 100% all the time so shud have 12v going to her she is running of my CPU fan header witch is set to 100%.
i just cant seem to figure out why it wont light up ive had the AIO installed for around 3 months so it isnt old.
any ideas fellas and ladys ?
Pclinde    197
The LED and pump are two separate components. You can request RMA for this, but you should not worry about the pump. :)
