rowers
Problem with CM Storm Mizar
rowers    0
Hi, I have problem with my new mice. On the left side of the mice, where is rubber grip, it's bend under pressure. My impression is that the materials are misaligned. Is it normal in this mice?
world    84
Any chance you can post a picture of it? It's supposed to have a rubber grip, so you probably have a defective one if there isn't a grip and it's flexing under reasonable pressure
Pclinde    197
Haven't seen that yet. No, it's not normal. Maybe you can contact the support/RMA?
Cheers, Pim
rowers    0
Cheers, Pim
Thank you for answer. So, then I have to go to the store or contact support.
world    84
Yea. If it's easy to, I would recommend going to the store (my preference, since you can get it exchanged immediately  :P) but contacting support is perfectly fine too :)
