Daniel Istudor
CM Quickfire Ultimate Driver ! Help!
Pclinde    197
It wasnt a specific web I just wrote that in google and read the random posts.I will lose info or something if I do that ?
No actual SSD or HHD storage. It won't harm your system. You will lose BIOS modifications/settings.
I did that and seems that nothing changed.
PD: Plugged the keyboard once more. I tried ALT+TAB quick just to check if it works, it worked. It worked for like 20 sec this time but after that none of the keys were working but I could change the light mode.
PD2 : Plugged again and all keys were working till the keyboard died again.
Pclinde    197
Hmm... This is really strange. How long did it work before the water incident?
I moved the keyboard near the radiator ( not sure if this is the correct english translation ) in a vertical position and now when I plug the keyboard works usually for some secs.
It can still be wet after so much time ?
PD:Worked for like 5-10 min and died again.Now everytime I plug it works for 1-3 min.
Pclinde    197
Hi Daniel,
Maybe we can make an appointment on Skype? Maybe I can help you out with remote control (Teamviewer).
Cheers, Pim
Insayan    0
 Does the keyboard die on your mac as well? Can you see the keyboard in computer management (right click This Computer>Manage>Device Manager)?
No, I sent the keyboard to a store.
Hi Daniel,
Cheers, Pim
We talked in skype :D ty for the help
