stardreamer77
Will a Nepton 240M fit in a CM 692 advance case?
hi..
i want to get a Nepton 240M , but i am not sure it will fit in the CM 690 II Advance case. can anyone help?
thanks.
my pc spec:
i3770k
ASUS P8Z77V-PRO
knud    129
Yes, you can mount it in the CM 692. You might need to put the fans in the plastic top cover, depending on how much clearance you get from the M/B and/or RAM.
Thanks... i get the Nepton 240M and finish install it. the fan can't place under the radiator due to the EATX12V power , so i place the fan on Top of the radiator. (outside the case but under the Top cove) . without any problem.
