TCUZ06
Nepton 280l - Broke seal on LED Cooler Master Lens/Window
TCUZ06    0
During installation of a Nepton 280L I pressed down too hard on the LED lens with the word Cooler Master on it.  The lens is still firmly in place but in does push in a little on the right side (where the "Rs" are).  Before I even fire up the PC, I was wondering if this screw-up is catastrophic.  I.E, will water pour out of the lens during operation.  Or will the pump not function correctly due to suction issues or whatever.  Basically, am I ok to turn on the computer because the lens is meaningless or do I have to remove and replace the Nepton 280L.  Thanks for any advice.
Pclinde    197
Hi,
You can always try, but at your own risk. The pump should not be affected by this.
Cheers, Pim
