nik69
CMSTORM Trigger Problem
nik69    0
 Hello i'm having an issue with my Trigger keyboard.
It started when i tried to install some drivers for a game pad.
So from then it doesn't work in bios, in my ps3 and in my second PC.
It power's up but i can't type anything(neither control it's led's via function key).
It only works when i'm having its application running in the background - only minimized at the taskbar.( If im having it minimized in notification area it doesn't work). But function key functions still don't work.
So im basically looking for a way to do a reset(?). Since it is not dead. Is it possible?
PS : I've tried it in multiple USB ports, several pcs and in a ps3.
MadmartUK    2
ive a problem half keys dont work  and the ones that do are wrong. ive checked settings and reset to default and all are correct and language settings,
ive raised a support ticket 00052140.
Mark Dawson    0
I just fixed my keyboard, i thought it was screwed half the keys not work to type the letter t i had press ESC key F1 was like n, i even tried the keyboard on PS3 still same problem. what i did to fix it is open the trigger software and go to profiles and select profile 1 and apply and now all keys are working i guess something in the profile got messed up in the memory of the keyboard so it wont matter if you trry it on another computer. i posted this on any thread but though better make sure u see it too.
Pclinde    197
Thanks! I will make sure we double check this.
Pclinde    197
Hi Madmart,
Can you please check this potential fix from Mark Dawson?
Cheers, Pim
  • Upvote 1
Pclinde    197
I found a problem this only works while trigger app is on desktop or taskbar not minmized or the problem comes back :/
Alright. Thanks for the update! I'll get back to you tomorrow.
