naripeddi
Compatible air cooler for i7-4790k
naripeddi    0
Hi,
I have built my new PC with i7-4790k processor (Socket LGA 1150) on Asus Z97-A motherboard. I fitted the stock cooler that came with the Intel processor. During idle time, the CPU temperature averaged about 36°C. Is this normal? I plan to do heavy video editing and encoding. I am sure in that case the temperature will go higher. Should I go for an aftermarket CPU cooler? If yes, then which CoolerMaster product is compatible with my CPU and motherboard? I read good reviews about Hyper 212 Evo, but its specifications do not list LGA 1150. Also, does CoolerMaster air coolers come with thermal paste or we need to purchase it separately?
By the way, my case is CoolerMaster K380.
Thanks for your help.
Regards
Sunday Morning    177
HI,
Hyper 212 EVO
  • Well-balanced cooling performance provides fin optimizations with perfect balance between high and low speed operations.
  • 4 Direct Contact heat pipes with the patented CDCâ„¢ (Continuous Direct Contact) technology - creating a perfect, sleek surface for heat conduction.
  • Wide-range PWM fan with unique wave-shaped blade design for excellent airflow.
  • Versatile all-in-one mounting solution supporting the latest Intel® LGA 1366 / 1155 / 1150 and AMD FM2 / FM1 / AM3+.
yes CM air cooler or liquid cooler coming with the thermal paste :)
naripeddi    0
Thank you very much for your reply. I will go for Hyper 212 EVO then.
Will it fit in the case CoolerMaster K380?
Also, is 36°C normal for a CPU temperature in idle state?
regards
Sunday Morning    177
regards
CPU cooler height: 155mm / 6.1 inch < Allowed
159 mm < EVO
iam not preety sure if the evo 212 can fitting into the K380
But we can ask admin ... might they have an suggestion
about the temp .. at 36c is preety good :)
Edited : You can also check our 120mm water coolers at this link : http://www.coolermaster.com/product/Lines/cpu-liquid-cooler/
knud    128
K380 wont be able to fit Hyper 212 EVO inside.
Have you considered the K280 or K282?
Create an account
Register a new account
Sign in
Sign In Now
