0hmyg0d
CPU temperature problem...
0hmyg0d    0
im using P3 800Mhz, Socket370..
last time i using da stock HSF.. now coz of da temperature is up to 6x'C.. so i change 2 CM Aero 7 Lite.. but i still cant solve da main problem.. after changed.. da temperature stop at 51'C whatever is full load.. when idle is 50...
i wan 2 noe wat happen 2 my CPU.. y damm hot bout it..
Ron    1
What case do you have?
How many fans are in there?
More details please...
fraxxx850    0
i think that there is some problem in your motherboard or in the installation of cpu cooler....the temperature it's very high for a p3....check all component...
zerospace    0
That's really hot for a P3... I assume you checked to be sure the CPU fan is still functioning? Try blowing any dust out of there too....
