Williams
Will a Nepton 280L fit in my case? CM ATCS 840
Williams    0
As the title says, I would like to know if the 280L will fit in my ATCS 840 case, and will I have to drill any holes or make any modifications to either my case or the radiator?
Gary Minor    0
I would like to do this also.
Can you tell me any more about the design of the mounting brackets?
How do I remove the top fans cover?
Is there an on-line installation manual for the 280L?
knud    129
I mounted a Nepton 280L in my ATCS 840 - use the 120mm fan mount option of the 280L, but you need to use some zipties for the part near odd.
But besides that, very easy to do.
http://imgur.com/NtZCoJc
Top cover fans removal: There is a screw on the backside of the case (at the top) which you need to remove. Then you can slide out the black mesh cover. Then the fans are easy to remove.
