hamnivlem
Quickfire Rapid-i (brown), some keys not lighted up
hamnivlem    0
First off, this is a great product. I love the overall build of the keyboard.
Okay, now for my problem.
Keyboard was fine for a month or so, until lately, some keys are not lighted up even with the mode where all lights are turned on.
Namely.. F3, F4, Q, W, Prt Sc, Scr Lk, Page up, Y, 8, C, V, left Alt, down arrow and a few others.
Could this be a macro/customization function or something where what I did was manually turned off some switches? If so, how do I reset it. Alternatively, how do I troubleshoot this.
Please help, thanks. Keyboard is only two months old, it worked fine weeks before.
world    84
If you want to do a bit of troubleshooting, try using the keyboard with another computer and see if the problem keys light up there. Also, the keys that you listed do not light up no matter what mode the lighting is in?
Also, is your rapid-i updated to the latest firmware?
I would recommend contacting support for this though, since it sounds like there might be something wrong with the keyboard beyond just a settings problem, especially if you try connecting it to another computer and it still doesn't work properly.
