Joss
CM Trigger Z setting macro
Joss    0
I have the keyboard model CM trigger Z
How do I assign at keys M1-M5 the same function as the keys "SHIFT" so when I press the button, for example, M1 works until I leave it, In the same way that happen when I want  to write capital letters.
Thanks
world    84
Do you mean you want the macro keys to be able to have a function when you hold it down and then release when you release the key?
So in your example, if M1 is mapped as "shift," then you can hold M1 and press a letter to get a capital letter.
CM Robert    2
Hi Joss, yeah, there's no way to assign m1-m5 as key function like SHIFT to those keys as they are intended for Macros and macro key combinations.
