Galiaker
Problem with nepton 280L pump
Galiaker    0
I have bought my nepton 280L 2 week ago and i have a big problem. My pump is running at 6000rpm and it makes a lot of noise. I want to configure my CPU_FAN but i don't know how to configure it.
My config :
- Maximus VII formula
- i7 4790k 4.0Ghz
- G.skill 16Go ddr3 2175
- Nividia geforce 780 Ti 3Gb
"Sorry for my english"
Sunday Morning    174
Hi Galiaker,
i just copy paste from previous page
Please connect both Jetflo fans to CPU Fan 1 and CPU Fan 2 since these two headers are usually linked in bios. Then connect the pump to any 3 pin header on the
motherboard. This should allow you to adjust both fans at the same time without interfering with  the Pump RPM.
if you have problem with the installation u can refer this link :
  and this : http://community.coolermaster.com/index.php/topic/11690-noisy-coolermaster-nepton-280l/
Just try help you out :D
Note* During installation Dont tighten the Screw or Bolt too much :D
Galiaker    0
i've connected my two Fans to CPU Fan 1 and CPU Fan 2  and my pump on Cha Fan  but no change. My pump running at 5500 rpm and the two Fans running at 1600 rpm and i can't configure.  You said connect my pump to any 3 pin header but on my MB i don't have any 3 pin header ( This could be the problem?)
CM Patrick    34
Hello Galiaker,
No this is not an issue. You can connect any 3 pin connector to a 4 pin header and it will still function the same.
Please let us know if you have any more questions.
Respectfully,
Patrick
CMUSA Support
