maxzamoraj
Help with installing LED strip on CM HAF X case.
maxzamoraj    0
Hello! I just purchased the HAF X and I decided to add a white LED strip to the inside of the case.
I know that the votlage of the red LED on the front is 2v. And my LED strip is 12v.
That obviously can't work, so I need suggestions! A friend told me I could use one of the power supply's cables with 12v and connect the strip to that cable, but I'm not really sure about that.
Help would be very much appreciated.
world    84
If your LED strip is 12v, connecting it to a 12v line on your power supply would probably be your best bet!
