guillaume
Cpu fan or Cpu opt ? Cooler master seidon 120m
guillaume    0
Hello,
I've juste one question about this water cooling. Where i have to plug the pump and where i have to plug the fan ? Today, i put the pump on the cpu-fan and the fan on the cpu-opt.
Thank you and have a nice day. (Sorry for my English, I'm french)
Guillaume
guillaume    0
Thank you for the answer.
i have a second problem, the screws which are given in the box are to small to fix the radiator and the fan together. How can i do ? do you think that cooler master have some longer screws?
guillaume    0
No, i have enough screws but there are too short (about 5mm), so when i try to fix the fan and the radiator only one or two screws stay the other are spinning uselessly in their holes.
Sunday Morning    177
if iam not wrong ... here is screw coming in the box
http://community.coolermaster.com/index.php/topic/11445-cm-seidon-120v/
According your chassis site .. this case support  120m cooling system :D
i just read it :  http://www.tomshardw...efine-case.html
                    http://pcpartpicker.com/b/MzwPxr
