Stevebit56
V8 GTS CPU cooler
Stevebit56    0
I want to know if the V8 GTS CPU cooler is it compatible with the new LGA2011-v3 processor for the new X99 Motherboards I know I need low profile ram which I have Corsair vengeance which is only 40 mm tall. I'm under the assumption that the Lga2011 old style and the LGA 2011-v3 are the same physical size but I'm not 100% sure just need someone that knows if it's compatible or I'm going to have to send it back. I hope I can use it because it is the coolest looking Air cooler I have ever seen. Thanks any help would be appreciated Steve
world    84
The older LGA2011 and the LGA2011v3 have the same mounting holes, so coolers compatible with LGA2011 should generally be compatible with LGA2011v3. Of course, that would depend on some other factors as well, such as motherboard heatsink height and ram placement, etc.
