Amos Ng Jin Hao
CMStorm Mech Audio and Mic Jacks not working
Hi all,
I've had the keyboard for awhile now. Just got a new headset that has the 3.5mm jacks for mic and audio. I plugged them in, installed the driver, but I still get no sound. The PnP USB sound device shows up on my Sound settings when I plug it in, and it shows the levels going up and down when I'm playing music, but the headset itself is receiving no sound.
I plugged the headset directly into my computer and it works perfectly, so it's not a problem with the headset.
The keyboard is currently plugged into a USB 3.0 port in my computer.
Any clues would help a lot.
Thanks for the kind help.
world    84
Hmm, if it works on your friend's laptop, then some settings might not be right on your computer :(
world    84
Just a quick check, but is the default sound device set to the correct one? (In both the windows control panel as well as the music program you're using)
Yep. USB PnP Device it says. When I unplug the headset from the keyboard it disappears, so I'm absolutely positive USB PnP Device means the keyboard's jack. The levels go up and down as well, but no sound comes out of the headset. As I mentioned before, the headset works on other laptops or if I plug it in directly to my computer, so it isn't a problem with the headset.
