Tim Duinker 1 Posted September 7, 2014 hello guys,i'm interested in buying the Storm Trooper for my First OverPowerd Gaming system that i want to buy in april 2015.and i want to put a Corsair Hydro H110 liquid CPU cooling kit in the mix.now is my question: Does It Fit on the ceiling of the case?the Hydro H110 has a 280mm radiator with 2x 140mm fans(dont ask about the with, i don't know that xD i'll get to that after i post this)i plan to use a ASUS MAXIMUS VII HERO motherboard. with 2-way CFX sapphire R9 290Xand 2 sticks of 8gb Corsair vengeance Pro 1866 memoryi can buy the H100i, but i don't know how much that will limit my i7 4790k overclocking potentialmaybe if its a no-go you might be able to suggest a CPU heatsink thats powerfull enough to cool a overclocked i7 4790k?thanks for reading -Tim Quote Share this post Link to post Share on other sites
Sunday Morning 177 Posted September 8, 2014 Hi there, According this link : http://www.coolermaster-usa.com/landing/trooper/home.php?page=cooling is support 280 radiator on the top also pls check this one probably can help you out : http://www.newegg.com/Product/Product.aspx?Item=11-119-245&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=h110&Page=1#scrollFullInfo&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=6146836&SID=rtjjyjw1rupv 1 Quote Share this post Link to post Share on other sites
Tim Duinker 1 Posted September 8, 2014 Hi there, According this link : http://www.coolermaster-usa.com/landing/trooper/home.php?page=cooling is support 280 radiator on the top also pls check this one probably can help you out : http://www.newegg.com/Product/Product.aspx?Item=11-119-245&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=h110&Page=1#scrollFullInfo&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=6146836&SID=rtjjyjw1rupv Thanks mohdnoh, i can't i missed that after 4 days of googling xD much appreciated 1 Quote Share this post Link to post Share on other sites
Sunday Morning 177 Posted September 8, 2014 Thanks mohdnoh, i can't i missed that after 4 days of googling xD much appreciated Hi Tim, Small problem .. we glad you enjoy with CM product Quote Share this post Link to post Share on other sites
Sunday Morning 177 Posted October 1, 2014 Case Solved and Closed Quote Share this post Link to post Share on other sites
