Laucien 0 Posted September 1, 2014 Hey everyone!, I'm looking to swap my current CPU cooler for the Corsair H100I and I've been reading a lot of threads and sites about if it would fit in this case and where to put it but I still have some doubts that was hoping you guys could help me with. I have the CM 690 II Advanced Edition (The edition that was available around 2011) and I'm looking to either mount it at the top in push only or at the bottom in push/pull. For the top mounting option I'm not sure if it will fit every combination of motherboard and RAM sticks or if some would be too close to the top to fit (I have the ASUS Maximus VII Ranger - A standard ATX mobo). Can I fit the fans (120mm with 25mm thickness) on top of the case but under the top cover?. Removing the HDD cage and mounting it at the bottom is what I'm really interested in but I can't find any data on the length of the tubes to make sure they can reach from the CPU all the way down to the rad while going over 2 GTX 770, does anyone have any info/experience on that?. Regarding the P/P config, should it take cool air from the outside, push it through the radiator and then out into the case towards where the HDD are or pull from inside the case to outside out the bottom?. Thank you guys and sorry for the noob questions XD. Quote Share this post Link to post Share on other sites
ScienceBoy 2 Posted September 5, 2014 i mount my corsair H50 with P/P config at at the top. just 1 cm left to the RAM my fan(s) setup pull from inside the case to outside of the top Quote Share this post Link to post Share on other sites
Sunday Morning 177 Posted September 11, 2014 Hey everyone!, I'm looking to swap my current CPU cooler for the Corsair H100I and I've been reading a lot of threads and sites about if it would fit in this case and where to put it but I still have some doubts that was hoping you guys could help me with. I have the CM 690 II Advanced Edition (The edition that was available around 2011) and I'm looking to either mount it at the top in push only or at the bottom in push/pull. For the top mounting option I'm not sure if it will fit every combination of motherboard and RAM sticks or if some would be too close to the top to fit (I have the ASUS Maximus VII Ranger - A standard ATX mobo). Can I fit the fans (120mm with 25mm thickness) on top of the case but under the top cover?. Removing the HDD cage and mounting it at the bottom is what I'm really interested in but I can't find any data on the length of the tubes to make sure they can reach from the CPU all the way down to the rad while going over 2 GTX 770, does anyone have any info/experience on that?. Regarding the P/P config, should it take cool air from the outside, push it through the radiator and then out into the case towards where the HDD are or pull from inside the case to outside out the bottom?. Thank you guys and sorry for the noob questions XD. try check this link : http://www.overclock.net/t/1144409/h80-h80i-h90-h100-h100i-h110-case-compatibility-thread-page-1-for-full-listings Quote Share this post Link to post Share on other sites
