LeeDavies
NotePal Ergostand Speed
LeeDavies    0
I just purchased a NotePal Ergostand to cool my Laptop. The box says that the speed is adjustable but I only see an on/off switch.... The current speed is so low that I don't even feel the air blowing on my hand. How can I increase the speed?
knud    129
Can you provide the part number?
Does it match with the one mentioned on the box?
LeeDavies    0
No. There is no number whatsoever on the box or the unit itself. There is no barcode present either. I bought it from Groupon SA. The box looks legit (purple and white) Just no instruction manual. The unit itself has 2 usb ports and an on/off switch. That is all.
juttt45    0
I bought it from Groupon SA. The box looks legit (purple and white) Just no instruction manual. The unit itself has 2 usb ports and an on/off switch. That is all.???
Pclinde    197
Can you share a photo of the package and unit?
