no5killz
CM Trooper Case , Fan Light Kable/Button
no5killz    0
Hello  :)
please help me with my problem.
i have the trooper case und in the middle of the panel is the button to switch the fan led on or off.
i have 2 new fans mounted (Enermax T.B.Vegas 12cm red led) the have also a button to switch the leds (no on-off switch, only a button like the panel one)
is it possible to connect the 2pin cable coming from the front panel to the 2 pin cable instead of the fan button ?
(attached a pic from the fan cablebutton)
i hope you know what i mean & understand my english :lol:
thanks for the info greeting Martin
Hi no5killz,
Welcome to the forum.  In regards to your question, I am afraid that is not possible. The Storm Trooper/Stryker provide power to the 2 pin cables going to the fans.  In regards to the enermax fans, they are set up as a toggle switch.  Please don't connect them as it will kill your fans.
  • Upvote 1
no5killz    0
thank you for the info. you are right ...
used a multitool to measure and the trooper button toggles only 12v on/off.
maybe it is possible to rewire the cables from the fan led power if there are 2 circuits.
