Rich Malpass
2-pin WST cable/connector
My case is a Storm Trooper. I'm still in the building phase. One of the cables coming down from the front panel plugs and lights has a 2-pin connect that is only marked WST. It is NOT the "HD LED", "Power SW" or "Reset SW" which are well marked. What is this cable/connector used for? Is it the PLED (power LED)? If so, it doesn't fit the pin spacing my mother board provides.
Thanks,
RAM
I would still like to know what this connector is for. But here's my status update. I finished building the PC and all is working good without this connector plugged into anything. The power light on the case comes on so I don't believe it is the PLED. Maybe this is an extra fan wire. If anyone knows for sure, please reply.
Sunday Morning    174
Thanks,
RAM
hi there,
iam not preety sure too :D
but if iam not wrong that cable use for LED fan
try check this link : http://www.coolermaster-usa.com/landing/trooper/home.php?page=faq
                           http://community.coolermaster.com/index.php/topic/9923-storm-trooper-stryker-wiring/
hope this can help you out :D
