normdawg
Stryker One Front USB 2.0 Port Not Working
normdawg    0
I just set up the Stryker and almost everything on my case has worked fine but I noticed one out of the two front usb 2 ports isn't working. The two usb 3 ports work fine and everything else on top works fine but just that one port. Could this be a potential driver issue, or can a usb port be dead? If anyone can try and help me fix this that'd be much appreciated.
Thanks in advance.
normdawg    0
Nevermind after running Microsoft's fix it along with restarting the computer it works fine. Seems like the fix it software is what helped since this was an issue for a few days after several reboots.
