Eyal Solomon
Seidon 240M on the top fan vent of the Enforcer case
Can I mount the Seidon 240M on the top fan vent of the Enforcer? (The case support 2x 12mm fans.).
If not, what is the best total case / CPU cooling configuration? (front, back and top).
Thanks.
kikoandr0id    0
if the case supports the 2 x 12cm fan holes, then you should be fine. my best advice is to (if possible) take the radiator and ask the employees at the store if you can check / put the radiator only to test if it can fit. next thing is to read reviews around for the case and see if anyone had ever fit a similar 240mm radiator inside the case.
As far as i can see here: http://gaming.coolermaster.com/en/products/cases/enforcer/ (i think its the case you are talking about), then the seidon 240m is not on the compatibility list. you can always mod the case to fit the 240m but i wouldnt recommend. i would rather go with this tower:
http://www.coolermaster.com/case/ultra-tower/cosmos-2/ ,
just because of the extra space.
hope this helps.
Sunday Morning    177
Hi there,
Refering from cooler master site .. we already notice that Enforcer Case cant fit dual radiator on the top but u can still put the radiator like Seidon 120V or Seidon 120M on the Rear
Hope this can help you
