LokkenJP
Help with CM K280 case front bezel
LokkenJP    0
Greets.
I bought a prebuilt gaming rig with the K280 case.
I need to install a new DVD drive, but i'm being unable to take off the front bezel as instructed in the CM k280 manual (for reference http://www.coolermaster.com/xresserver01-DLFILE-P130218052823fc-F1303040066ab44.html )
The instruction manual is not very specific about this point (2.5.1 in the leaflet), and I'm not able to figure how the :) take it off.
Anyone can help?
Thanks in advance, and sorry for such a noobish issue.
L
To remove the front panel, please pull it from the bottom side at an outward angle.  It will require some force, then the front panel will pop off.  If you have further questions, please let us know.
LokkenJP    0
Many thx for the answer.
I tried to pull it that way, but I was unable to pop it off. Being unsure about how it was done, I pulled gently to avoid breaking it off. Tomorrow I'll try again, this time a bit harder :)
Regards
