Pilgrimx 0 Posted December 30, 2004 My front 80mm fan just broke down. Before I break anything of the chasis, could someone show me (step by step) how to remove the front panel in order to access the screws of the front fan? The manual ain't much help, it merely says "remove front panel". Question is HOW? Thanks! Quote Share this post Link to post Share on other sites
bronney 0 Posted December 30, 2004 You yank it uniformly from all side, bit by bit. Best to start from bottom. If the DVDROM drives get in the way, remove the drive first or you'd tear out it's bezel. I already broke 1 leg off my centurion 5 bezel hehe, 5 to go. Quote Share this post Link to post Share on other sites
mak45 0 Posted December 30, 2004 1) Start By Removing everything in ur drive bay. (5 1/2" and 3 1/2") 2) Remove these Screws then squeez the big black knobs: 3) Then remove the front bezel slowly not to tear the wires. 4) Remove screw of the fan than replace with the new fan you have Quote Share this post Link to post Share on other sites
Pilgrimx 0 Posted December 30, 2004 Thanks guys!! Sounds like a handful just to change one fan! Quote Share this post Link to post Share on other sites
Pilgrimx 0 Posted December 31, 2004 1) Start By Removing everything in ur drive bay. (5 1/2" and 3 1/2")2) Remove these Screws then squeez the big black knobs: 3) Then remove the front bezel slowly not to tear the wires. 4) Remove screw of the fan than replace with the new fan you have Btw mak45, the screws can only be opened by alan-type keys right? Quote Share this post Link to post Share on other sites
bronney 0 Posted December 31, 2004 Please be very careful when you squeeze the black knobs, that's how I broke mine off. It actually snaps. Quote Share this post Link to post Share on other sites
mak45 0 Posted December 31, 2004 uhuh, u need those hexagon screws. BTW Brooney, thise black knobs for cavalier is little rubbery, anyway try not to yank it out. Quote Share this post Link to post Share on other sites
