zaythe
Coolermaster HF Top Fan - Can I Do Without
zaythe    0
Hi,
I have been fixing a desktop for a friend, Its an 2nd Gen i7 with Corsair Watercooling system and a Nvidia 570GT. It is all in a HAF 912 case which has a huge top fan in the case.
When the machine turns on its like a plane taking off....I am just wondering whether the top fan is really needed due to the cooling already in the case.
Any guidance would be appreciated
Cheers
John
jaimelmiel    0
The noise may very well be from your cpu cooler. It will go to full speed till your bios loads your Pwm fan Defaults
then it quiets down.
jaimelmiel    0
Yes you do need that top fan for good airflow. I Have a Gamming Machine with a Haf 912 case. I replaced the 200mm Fan on fop with two coolermaster R4's.
I did it for more airflow. You should be ok with your setup.
n2bsprcool    0
So I posted a thread about this, and nobody has responded.
Anyway, I think some fans running "upside down" will make more noise than usual. I have a top mounted JetFlo and it's noisy as :), and annoying as :). It's kind of a "wobbly" noise or a "humming" noise.
I'm probably going to set all case fans to silent mode and CPU fans to normal mode and see if it fixes it.
Again though, I think most fans are made expecting to be run in a certain orientation.
But i'm surprised so many people here seem to miss the point as to why a fan might make noise. Some noise people are describing are not normal operating fan noise, rather noise from a fan that is out of balance.
amirite?
