Vitiokas
Seidon 240M compatibility with CM 690 II Advanced
Vitiokas    0
Good day.
I'm going to buy Seidon 240M cooler, but not sure about compatibility with CM 690 II Advanced case. If someone had experience installing this cooler please let me know.
Thank you.
cota472    3
I have the cooler but not that case, but from the specs I found on the case it should be able to accept it where the top case fans are. Be careful when installing as the screws that go into the radiator can be stripped easily if you over tighten.
