CM_Noobie
200mm fans included in CM cases
CM_Noobie    0
Hi all,
I'm just wodering if the 200mm fans that are included in some cases like in the CM 690 III is a megaflow.
They have the same look with the megaflow, cause I'm looking for a 200mm fans and having an eye with megaflow.  A friend of mine said he has a 200mm that comes from a case and said it'sa megaflow, and he wanted to trade it for a 2 120mm sickle flows, which I have.
Just wanted to know if it's a megaflow before doing the trade, cause I'm looking for a quite 200mm fan and megaflow seems a good fit.
Hope someone can shed a light about this matter.
I'm still new to this forum but been a cooler master fan for a long time.  Don't know where to exactly put this topic but just move it if it needs to be.
CM_Noobie    0
Anyone?  Just want to make sure if they are the real megaflow cause I read a lot of complains about them in some other sites.
world    84
You've only waited less than 2 hours for a response :P
But as far as I know, the fan in the CM690 III is probably NOT a megaflow. It likely has similar properties, but doesn't exactly match up with a megaflow.
CM_Noobie    0
Thanks for the response. Yeah I heard of that too. But really wanted to here directly from coolermaster about this. I will wait for them to respond to this thread.
But other thought will also be accepted if you ca share something related to this matter.
Also read a lot about the included 200mm fans are louder than megaflow, so I really need to confirm this so that I can decided to buy a true megaflow or use the included.
Never had megaflow yet.
CM_Noobie    0
I'm currently using a 690 III. The stock 200mm front fan is similar to Megaflow, but without LEDs and probably not the same materials used. It's just an add-on - don't expect much about it. They probably have the same RPM. It looks like this http://www.newegg.com/Product/Product.aspx?Item=N82E16835103178
Yeah that's where I get confused cause it looks like the Megaflow and some says it doesn't perform the same.  And also in the website it also doesn't say that it's a megaflow or a stock fan only.
They should at least indicated it or something, somehow.
Create an account
Register a new account
Sign in
Sign In Now
