Mmarcabian
Adding more stock LED fans to Trooper
Mmarcabian    0
I'm looking to mount a total of six stock Cooler Master fans with two pin LED to my trooper.  I'd like to keep them all on the control panel.
I know that the three pin leads will support two fans (or even three) per channel just fine, as far as fan power goes.
My question is whether I can split the two pin LED on/off  leads, and if so how many ways?
knud    128
Fans you can split indeed. 2 or 3 per channel should be okay - but you might need to experiment with it. All depends if you need them to run at full speed all the time.
Make sure to buy the correct fans: http://www.cmstore.eu/cases/cosmos/cosmos-ii/120mm-red-led-fan-on-off-2/
As for the LED connection: This is something I need to check in more details and need to double-check with CM directly. I will update this thread as I have more information.
Some more 3rd party info: http://www.overclock.net/t/1104349/the-official-cooler-master-storm-trooper-storm-stryker-club/430
And apologies for the late replay :)
